DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Do I need a shower pump?
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
neilikins
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 01, 2007 11:34 am    Post Subject:
Reply with quote Thanks
I am having a shower installed in a downstairs bathroom and trying to ascertain if i require a pump. The cold water tank is in the loft of the 2 storey house and the shower head will be approx 9 feet from bottom of cold water tank.
Does anyone know if there is a calculation model I can use to work out if a pump is required? Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Breesey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 01, 2007 11:36 am    Post Subject:
Re: Do I need a shower pump?
No you wont need a pump. Unless you want a particularly powerfull shower of course.
Back to top
 Alert Moderators
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Sun Jul 01, 2007 11:37 am    Post Subject:
I work it out to be around 1/3 of a bar. Not great. When a shower pump can easily give 1.5 bar!
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jul 01, 2007 11:44 am    Post Subject:
Agree with Rob, each storey (approx 10ft) is equal to about 1/3 bar pressure drop/increase.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
neilikins
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 01, 2007 11:48 am    Post Subject:
Thanks everyone for quick responses. Looks like a pump is needed. Does anyone have recommendations for a quiet model?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jul 01, 2007 11:49 am    Post Subject:
Never heard of a 'quiet' shower pump unfortunately. Been the subject of many a discussion on here. Suggest you do a search icon_wink.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Breesey
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 01, 2007 12:01 pm    Post Subject:
A pump isn't 'needed' but would give you a more powerfull shower icon_rolleyes.gif If you want a quiet shower don't get a pump icon_wink.gif
Back to top
 Alert Moderators
outmyway
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 20, 2009 9:18 pm    Post Subject:
Interesting thread ..
I'm putting a shower room in my basement and this is calculation just what I'm looking for!!
Drop is 16ft ... so guess about 0.5 bar pressure .. uuhhmm
(cold water tank is in upper portion of airing cuboard above hot cylinder)
Could I put a pump in my basement or is that too far away from the cylinder/header tank to work OK?
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Fri Mar 20, 2009 10:45 pm    Post Subject:
__________________
Richard C
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Fri Mar 20, 2009 10:49 pm    Post Subject:
You should be OK @ 16ft but check as many of the smaller pumps have restricted maximum static head.
__________________
Richard C
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Sat Mar 21, 2009 9:16 am    Post Subject:
Whether you need a pump or not depends on the water pressure your choice of shower is designed to work with.
A lot of the brassware on offer is designed to work with mains pressure water, with a minimum pressure of 1 bar, and is sold by people who think a bar is where you go to ask for a bottle of alcopop icon_rolleyes.gif
Shower valves and heads designed for use at gravity water pressures as low as 0.1 bar are available. They don't pin you against the wall and strip the flesh from your bones with a high pressure jet, but they are capable of getting you very wet very quickly.
If you are dealing with a certain high street bathroom supplier, you may find you need to take an iron bar with you, and use it to explain to the sales erk exactly what one bar of pressure means by applying it just behind their left ear....
I would try to avoid the complication of using a pump on the basis of what isn't there doesnt make any noise, doesn't require an electrical connection and doesn't go wrong, but make allowance for fitting one if it later proves necessary.
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
outmyway
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 21, 2009 11:31 am    Post Subject:
I might put a pump in whilst I'm at it.
I'll be tapping off hot/cold from under the kitchen units to route to the shower room below, so can easily site a pump there, plus have electric sockets etc.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Sat Mar 21, 2009 12:06 pm    Post Subject:
In most cases & to work efficiently, shower pumps require their own, dedicated feeds direct from the hot/cold storage tanks, generally in 22mm. Teeing off the kitchen supplies (which are probably only 15mm) is definitely not a good idea; additionally the kitchen cold supply will probably be mains pressure which, again, is unsuitable for most pumped installations.
I would suggest you do a little more research into the general requirements of pumped systems before you go any further.
__________________
Richard C
Back to top
 Alert Moderators
outmyway
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 21, 2009 12:27 pm    Post Subject:
Thansk Richard.
Your right it would be mains cold water from my kitchen - downstream of my water softner - uhhmmm!
Could I use a pump on just the hot and use the cold at mains pressure?
Or would that cause mixing/thermostat issues at the shower?
My exisiting showers are fed pumps to.from with 15m pipework (which are tapped off the 22mm hot cylinder pipes close by) - which works ok.
Maybe I should stick to a 16ft head giving 0.5 bar - a reasonable pressure shower?
Back to top
 Alert Moderators
outmyway
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 21, 2009 12:30 pm    Post Subject:
PS: Just thinking ..
My mains cold water supply is high pressure (guessing at >1 bar) .. if I use that with my 16ft head of hot from the cylinder to my basement shower would that give more than 0.5 bar combining the two pressures?
Gues it depends on the mix of hot to cold?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Shower Pump Selection 3 520 Wed Aug 23, 2006 11:11 am
Shower Pump 6 2960 Mon Jan 29, 2007 1:42 pm
Hansgrohe shower pump 3 280 Mon Jan 29, 2007 10:37 am
Pulsing shower pump 3 1480 Wed Mar 01, 2006 8:48 pm
how to fit a shower pump 3 2600 Wed Jan 31, 2007 8:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
