agh100
Joined: 14 Jun 2007 Posts: 28 Location: Kent, United Kingdom
Posted: Mon Jul 02, 2007 11:48 am |
Hi
I have some new lino to fit in out bathroom. The floor has floorboards at the moment. Do I need to fit some plywood on top of them before putting the lino down? If so, what sort of plywood and where do I get it?
Once the lino is down do I need to seal it round the edges to stop any splashed water getting to to the plywood or floorboards?
Thanks |
mattysupra
Joined: 30 Jan 2007 Posts: 2154 Location: West Midlands, United Kingdom Thanked: 45 times
Posted: Mon Jul 02, 2007 5:19 pm |
Yes you should plywood floor first. Normally 6mm depending on how bad the floorboards are. I sand the boards flat before i plywood so i can get away with 4mm plywood. It needs to be exterior grade. Can get from local timber yard, B&Q etc. And it is recommended to seal edges in a wet area. You should also fit the flooring and plywood slightly short. Your sealant will cover the gap. |
breezer
Joined: 03 Jan 2003 Posts: 23330 Location: Sussex, United Kingdom Thanked: 24 times
Posted: Mon Jul 02, 2007 9:08 pm |
we didn't  guess what, you can see the floorboard "patterns" |
agh100
Posted: Tue Jul 03, 2007 8:59 am |
thanks for the advice. I will get some plywood and give it a go. The room is only 1.5m x 0.75m and then the toilet the same size - so I'm hoping it wont be too difficult!
Do I just nail the plywood to the floor boards? |
mattysupra
Posted: Tue Jul 03, 2007 7:39 pm |
ring shank nails. Not panel pins etc. Or screw. but heads can show through |
