scd3
Joined: 06 Jul 2007 Posts: 3 Location: United States of America Thanked: 0 times
Posted: Fri Jul 06, 2007 12:57 am Post Subject: preparing old floor for new tiles... |
i have an old ceramic tile floor (11 yrs old)...i want to pull up the old...not a problem, tiles are popping and put down new tiles. i see backer board under the old tiles. can i pull up the old, clean off the new backer and install the new tiles? |
gcol
Joined: 22 Sep 2005 Posts: 6580 Location: Lancashire, United Kingdom Thanked: 12 times
Posted: Fri Jul 06, 2007 2:48 pm Post Subject: |
I think I'd be wanting to know why your current tiles are "popping" before even considering laying new ones.
p.s. there is a seperate tiling forum ya know.  __________________ If I'm curt with you it's because time is a factor. The Wolf. |
scd3
Posted: Fri Jul 06, 2007 3:13 pm Post Subject: |
i thought i was in the tile forum?....this site is very confusing  . not sure why the tiles are popping...they seemed to have loosened over the years, the grout has cracked and the tiles have loosened from the backer board. |
gcol
Posted: Fri Jul 06, 2007 8:35 pm Post Subject: |
Sounds like you need to stiffen up your floor beneath the backer board. I don't use backer board cause it doesn't add much rigidity compared to ply wood. Look at replacing the backer board with ply and then re-tiling with flexible powdered adhesive.
| scd3 wrote: | | i thought i was in the tile forum?.... | Nope, you're in flooring. As it says under the title - "All aspects of flooring and stairs discussed here except tiling." There's a seperate tiling section.  __________________ If I'm curt with you it's because time is a factor. The Wolf. |
