DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Salamander 2Bar Pump
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ianfraser
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 7:34 pm    Post Subject:
Reply with quote Thanks
Hi. Fairly novice to plumbing but and like advice. Fitting a shower pump that has some anti virbration connectors (basically 8 inch flexi hoses) which are 22mm tap onto the pump at one end and and 15mm push fit at the other. 4 of these and are for hot and cold in and out of the pump.
All pipework from the hot water cylinder and cold water storage is 22mm which went directly into the old pump using old valve and tap connectors which I want to get rid of. I'd like some advice on how you would take the 22mm into the 15mm pump connectors (do you need a reducer, or can you get flexi, copper?). Or, would you not use the supplied hoses and just get 22mm all the way into the pump? Thanks in advance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 8:09 pm    Post Subject:
Not entirely sure what you mean; but yes use the suplied hoses and run everything in 22mm.
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
ianfraser
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 8:31 pm    Post Subject:
Salamander 2 Bar Pump
Sorry maybe i wasnt clear. The copper pipes are 22mm, the hoses that come with the shower pump are 15mm. Would you bin the hoses and just run 22 mm all the way to the pump, or reduce to 15mm. If you would reduce what do you need to do this?
Cheers.
Back to top
 Alert Moderators
RSF
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 08, 2007 8:37 pm    Post Subject:
Is it a new pump? The reason I ask is I have recently had a Salamander pump fitted and the flexi hoses are not 15mm, they are 22mm.
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 17 times
PostPosted: Sun Jul 08, 2007 8:56 pm    Post Subject:
You must use the flexible hoses. Just reduced the 22 copper to 15 copper with a soldered or compression reducing coupling.
Back to top
 Alert Moderators
ianfraser
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 09, 2007 8:12 pm    Post Subject:
Will replacing the supplied 15mm hoses with off the shelf 22mm hoses cause a problem? Is 15mm enough to get sufficient power to the shower?
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 09, 2007 8:16 pm    Post Subject:
Use the ones supplied and get a set of reducers - no need to make work for yourself.
__________________
Regards
Dan Robinson
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Lets correct myself boiler @2bar 9 380 Sun Aug 01, 2004 3:03 pm
salamander CT50 installation. Pipework on pump? 8 900 Sat Nov 29, 2008 6:53 pm
Salamander CT50 Shower Pump not switcing off. 2 360 Sun Dec 21, 2008 3:12 pm
Salamander pump esp 75 cpv temporary lock out 4 140 Sun Jan 04, 2009 11:09 am
salamander shower pump 8 1240 Sat Nov 29, 2008 1:06 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
