Joined: 10 Jul 2007 Posts: 26 Location: United Kingdom Thanked: 0 times
Posted: Tue Jul 10, 2007 11:18 am Post Subject:
weak power shower
I've installed a 1.5 bar pump under my hot water cylinder, the cold tank is above in the attic both connected with 22mm pipe reduced at the pump to 15mm inlets.
the shower is back to back with the airing cupboard, 2m max from pump to shower, each outlet (15mm) passes through a 90 degree elbow, the mixer valve, a 90 degree wall plate elbow, 90 degree outlet elbow and the handset.
the result is a shower comparable with the mains supplied electric shower in the main bathroom rather than being pinned to the floor in a torrent of hot water
is there a right angle too many or do i need a 2 or 3 bar pump?
Posted: Tue Jul 10, 2007 9:01 pm Post Subject:
Thanks for the reply
The shower head is pretty standard 3 mode head
the hot is tee'd into the 22mm feed from the top of the cylinder at a point just lower than the bottom of the cylinder - maybe not as good as a dedicated feed from a surrey flange connection - I haven't tried it with anything else turned on but even with everything bar the shower turned off its still a lack luster power shower
I've since had a look at the Salamander web site and I think the pump may have been the wrong choice and 2.25 or 3 bar would deliver the invigorating shower I was hoping for!?!
Joined: 25 Aug 2003 Posts: 9195 Location: Surrey, United Kingdom Thanked: 2 times
Posted: Tue Jul 10, 2007 9:24 pm Post Subject:
Forsh wrote:
as opposed to...?
as i understand it teeing into this pipe is not incorrect - its effectively 22mm from cylinder to pump
It is incorrect as it could pull air and give you TUM TUM TUUUUUM poor pressure
both hot and cold feeds should have their own independant feeds, IE cold a new tank boss and the hot on a surrey (or if you ae a flash wotsit Essex) flange
__________________ If at first you don't succeed, remove all evidence you ever tried.
Posted: Tue Jul 10, 2007 9:42 pm Post Subject:
Gasguru wrote:
Did you flush all the pipework - perhaps the filters in the pump and shower are clogged( if fitted).
I haven't checked but will do
Gasguru wrote:
Are you using speedfit pipe and fittings - these can be restrictive.
Yes, between the pump and flexibles (13mm bore) connected to the shower but as the runs are fairly short I'd have thought the pipe work after the mixer would be the worst case (wall plate elbows)
Gasguru wrote:
Some showers are designed for very high presures so your pump may not be adequate - check the technical specs.
this is what I'm thinking but posted the initial question to check if all else is ok - there are issues but I'm not convinced they add up to enough to cause the problem
Joined: 26 Oct 2004 Posts: 2624 Location: Surrey, United Kingdom Thanked: 5 times
Posted: Wed Jul 11, 2007 8:35 am Post Subject:
What is the make and model of shower.
If it is a thermo then basic models have reduced waterways to restrict flow, allowing a cheapo slow reaction time cartridge to shut off the water before a large volume of hot has passed.
The better thermo showers have a faster cartridge and therefore are designed to permit a better flow rate.
Posted: Wed Jul 11, 2007 9:16 am Post Subject:
the area is a soft water area so no problems with limescale
I fitted the pump a while ago but only just finished the ensuit so I'll have to check the plumbing but I'm pretty sure the reason I didn't use a surrey flange was because the cylinder doesn't have a threaded boss at the top
the shower valve is a simple mixer - not thermostatic
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Wed Jul 11, 2007 6:48 pm Post Subject:
I don't want to be too rude about the pump; but I have never seen a manufacturer say that fitting it off the cylinder the way you describe would be OK. I am surprisede they do; they also mention an Essex Flange - that would be a better method IF you can't fit a Surrey flange on.
Your cylinder will have a threaded tapping at the top - again I've never seen otherwise.
__________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Joined: 04 Jan 2007 Posts: 238 Location: Lancashire, United Kingdom Thanked: 1 time
Posted: Wed Jul 11, 2007 8:00 pm Post Subject:
There is nothing wrong with teeing off the hot pipe to go to the pump, provided it's below the tee that goes up to the open vent.
In an ideal world you should use one of the aforementioned flanges however replacing an existing cylinder outlet to get a Surrey/York flange on can be an a**e and Essex Flanges are easily dropped into the cylinder.
The only problem I have found putting a pump in like this is that if a hot tap is run for a while, the pump may chirp on when the tap is turned off however this is easily solved with a check valve.
I would put money on there being a blocked filter somewhere in the system that's causing the flow problem. You certainly don't need a higher pressure as there's no way you've got 1.5 bar resistance in the pipes to the shower if they are 22mm (1.5 bar = 15m of vertical height!!)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
