DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
seal on double glazing
This topic originated from the How to page called Draught proofing windows and doors
Click here to return to the page called Draught proofing windows and doors.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
house46uk
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 23, 2002 9:07 pm    Post Subject:
Reply with quote Thanks
the seals have perished on my patio door what can I do
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Sun Oct 27, 2002 10:05 am    Post Subject:
Re: seal on double glazing
I reckon I've got the same problem - but on my windows. Cold air gushes in (and rain too at the bottom apex oof each window),
What to do?
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Wed Oct 30, 2002 1:37 pm    Post Subject:
I experienced shrinking seals on my UPVC windows, leaving gaps at the corners that let the rain into the frame. The solution was simple - remove the seal (it should pull out with the help of a blunt scraper to hook it), then give the seal a good stretch to lengthen it a bit, refit by pushing it back in, and finally put a spot of superglue at each end to stop it shrinking back again. Start with the bottom and top seals then do the verticals. Mine has been absolutely fine since.
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Wed Oct 30, 2002 10:28 pm    Post Subject:
where can I buy the rubber seals
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Post double-glazing damp 6 2060 Tue Jan 14, 2003 11:04 am
Temporarily removing double glazing 4 5260 Wed Jan 22, 2003 10:09 pm
Recommend Double Glazing Company? 2 1080 Wed Feb 26, 2003 8:27 am
Double glazing 3 940 Sat Nov 16, 2002 9:33 pm
can any1 confirm bad reports of B&Q double glazing insta 3 900 Wed Oct 02, 2002 11:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
