1 radiator not working
14 Jun 2007
West Midlands
I have a problem not so now but will in the winter, I recently installed new radiators up stairs as there were not any when I moved in, when I turned on the heating all of them worked but found a leak down stairs as I changed all the thermostats i then had to turn off the heating & water supply take the thermostate off the radiator and resealed it then turned on the water and heating now all of them work except one down stairs in the hall way what could be causing this? can anyone help, I have turned off all the radiators except that one but it still hasnt worked.
could be a blockage air or sludge maybe
ensure that the rad valves are open fully on it.
make sure you have turned off the hot water side of the system and shut any bypass valves as well.
also try turning the pump the other way it does sometimes work.
try these first and if they dont work there are some other tricks we can try
Sorry get someone in if you really dont have any clue you could do damage so I am done now
sorry
