New2Game said:Is it ok to upgrade main bonding from PME to CU with 16mm Cable simply by isolating supply then making connections at CU then to the PME earth terminal?
RF Lighting said:Have the DNO provided an earth terminal for you to connect to?
You are not allowed to connect direct into the head.
luminaire said:
New2Game said:Its defo PME and already has 10mm into side of head, so its just a case of connecting a bigger cable
JohnD said:if you have a PME supply, the supply head will have an earth terminal on the side of it. You can connect your 16mm G&Y to that
