radiator removal
13 Jan 2007
Midlothian
I need to remove radiator in order to replaster wall,this radiator is one that does not have a TRV,but has isolating valves at each end.I also have another radiator of wall at present. Is there a set procedure for reinstalling/filling this radiator. ie the one with the isolating valves?
Terrywookfit;- Sorry for appearing to be thick,but I take it that this rad gets closed off at both ends,removed to allow access to wall,replaced afterwards then reconnected, and refilled releasing any air.
Spot on!!
Dont forget to repressurise system if on a sealed system!!
ie: If you have no header tank!
