DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
floor tiling
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
preston
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 19, 2007 10:34 am    Post Subject:
floor tiling
Reply with quote Thanks
I want to ceramic tile a kitchen/breakfast room, that has a part concrete, part wooden floor, how should the floor be prepared?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Fri Jul 20, 2007 8:24 am    Post Subject:
Welcome to the forum.
I'm assuming here that your wooden floor is floorboards.
Option 1
You'll need to overboard the floorboards with 12mm wbp ply (exterior ply) screwed every 200mm all over the face of the sheets. The sheets should be staggered so as not to get 4 corners meeting in the same spot. You need to overlap the ply onto the concrete section by about 450mm and make sure that it's glued and screwed to the concrete.
Fitting the ply will mean that your concrete section will almost undoubtably not be at the same level now. (I'm assuming that the floor was all on the same level to start with.) So now you need to raise the concrete section to the level of the newly fitted ply using self levelling compound.
Option 2
When you overboard the floorboards as above, you do the same to the concrete section. You'll need to stick the sheets to the concrete and I'd add screws too (every 450mm or so). If you go down this route, make sure that the sheets of ply overlap the transition line where the flooring changes from concrete to floorboards.
When tiling you must use a flexible powdered adhesive. I swear by Bal single part flexible adhesive and won't use anything else when tiling onto wood. Grout must also be flexible too.
__________________
If I'm curt with you it's because time is a factor. The Wolf.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Priming WBP before tiling floor 11 1140 Tue Feb 27, 2007 3:35 pm
Floor tiling: discard old floorboards and replace with ply? 6 1020 Thu Apr 20, 2006 9:06 pm
floor tiling without spaces 5 500 Wed May 09, 2007 6:59 pm
Floor Tiling 9 16380 Sun Oct 23, 2005 8:39 pm
Tiling on bathroom floor 4 1280 Wed Jun 21, 2006 6:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
