DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Noisy Central Heating
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 6:03 pm    Post Subject:
Reply with quote Thanks
I have a Triancogas 45/60 wall mounted boiler and recently the heating has become very noisy. When the boiler (initially) starts up there is a rushing sound from the water, almost as if it's having a surge ,or even like it the water is boiling. This lasts for about 60 seconds and then goes away, but from then on it comes back every 5 minutes or so whilst the boiler is on. I guess the best way I can describe the noise is like a surging sound.
I've tried bleeding the radiators, but there was no air in them. I've also tried setting the pump at different settings, but the noise is still there.
What do you think it could be?
Ian
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Wed Jul 25, 2007 6:53 pm    Post Subject:
open vented system?
possible choked cold feed.
Back to top
 Alert Moderators
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 25, 2007 9:53 pm    Post Subject:
Sorry, yes it's an open vented system.
By choked feed I take it you mean it's not getting enough cold water to it? Where should I start looking?
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Thu Jul 26, 2007 5:33 pm    Post Subject:
at the header tank.
the 15mm pipe that exits the smaller of your two tanks will probably join a 22mm pipe somewhere in your house. get a magnet and see if it will stick to the pipes round this junction. if it does there is a good chance that is your problem.
you can always temporarily back fill your system through the vent pipe that you might have looping over the small header tank.
Back to top
 Alert Moderators
gasandoilman
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 26, 2007 6:35 pm    Post Subject:
you say no air comes out the rads when u bleed them but do you get water ?
Your boiler could be kettling i would get some fernox for kettling first or DS-40
__________________
life is not a dress rehersal-enjoy
Back to top
 Alert Moderators
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 26, 2007 8:26 pm    Post Subject:
Yes I get water out of the rads when I bleed them - infact water comes out straight away.
And kettling is an excellent way to describe the noise - it's just like a kettle coming to the boil.
I'll try the fernox, but also have a look at the header pipes, but can you explain more about why the magnet will stick and if so what that means, but more importantly what to do to fix it.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu Jul 26, 2007 8:48 pm    Post Subject:
Magnet will stick because blockage is iron oxide sludge. If you find this it needs to be cut out and replaced.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 27, 2007 5:15 pm    Post Subject:
Ah, I see.
Thanks all - several things for me to look into.
Back to top
 Alert Moderators
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 08, 2007 10:02 pm    Post Subject:
Ok, I bought some Fernox for Kettling reduction and put that in. That's reduced the rushing sound (still there, but fainter), but now every time the boiler kicks in the radiator nearest the pump rattles and vibrates like hell for a few minutes and then stops.
What's happening now? Tried bleeding the rad, but no air.
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 08, 2007 10:08 pm    Post Subject:
Does it have trv fitted or normal lockshields?
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Wed Aug 08, 2007 10:11 pm    Post Subject:
Is the pump on setting "2" ?
Tony
Back to top
 Alert Moderators
BGTECHY
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 09, 2007 12:41 am    Post Subject:
stop **** footing around mate, get it flush and fit a magneclean.
Back to top
 Alert Moderators
Westers
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 09, 2007 4:29 pm    Post Subject:
No TRV's and pump is now on setting 2 (it was on setting 1). I did that after I'd posted on here and it seems to have cured it - for now.
LOL @ BGTechy - I like a no nonsense approach icon_lol.gif I reckon you're right though and can't do any harm.
Cheers all.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central Heating noisy pump 4 440 Sun Aug 24, 2008 3:13 pm
Noisy central heating 2 600 Sun Mar 14, 2004 12:59 pm
noisy central heating system 2 580 Thu Feb 28, 2008 9:31 pm
noisy central heating system 5 6660 Thu Oct 25, 2007 11:10 am
NOISY CENTRAL HEATING RETURN PIPE 2 320 Mon Feb 26, 2007 7:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
