As soon as machine is switched on, water pours from inside onto floor. Checked all external pipes are connected fine. Cleaned filters. Seems to be between the inlet pipe connection and the drum at the top of the machine. Pipe or pump come loose inside? Worked perfectly when used yesterday, then like this when tried to use today. Any ideas before I bite the bullet and call an engineer out?
