Concrete or mortar for Paving Slab Edge?
27 Jun 2007
Devon
Hi
I have lowered the ground level all around the house to one patio slab width. This uncovered around 9 airvents and some points the patio was 2 courses above the dpc!
Under the slabs was mortar, shingle and hardcore, as you can imagine there is now some gaps under the slabs that are left. What I would like to do is put an edge under the slabs (against the hardcore etc) to make it look better and hopefully support the slabs.
Can I simply buy a bag of cement or mortar and pile it in the gaps and smooth the edge? What is the best material and method for achieving this?
Regards
mix sharp sand with cement at 4:1, not too much water and pack it into or under any voids.
Thanks for the swift response. I will have a go during the week! Do I need to get a board or something to prop up the cement while drying or will it be a stiff mixture that will stand up on its own?
Regards
Regards
correct! add little water to the mix and this will give you a slump free mix that can be successfully shaped to a degree.
Hiya,
Just to let you know I have completed the job at last and your advice worked a treat!!!!
Only problem was I didnt wear gloves and and the sharp sand has ripped the skin of my fingers :eek:
Thanks for your help, onto the next job!!
Make sure your pint doesn't slip through your super smooth fingers :D
this is no joke.
it used to happen to me when i first started bricklaying. the condensation on the pint glass actually felt slimy, due to fingerprint-less fingers. pints do slip and the slipping sensation is numbed due to the wear.
honest!
