RedHerringbone
Joined: 05 Aug 2007 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Sun Aug 05, 2007 10:27 am Post Subject: Parquet Queries |
Couple of questions...
As per suggestions I will leave an expansion gap around the sides and use moulding to cover. But what do I do in the doorways with tricky architrave - I will use a handsaw and cut underneat so the the parquet slides underneath it - that can happily accomodate the expansion gap - but what about the moulding and arhitrave - that'd just look silly as it's so curvaceous...
Also, is there a definitive post on laying the initial line down the middle of the floor and marking out where you do your first line of parquet, I am doing a hall with a wiggle which then goes into a kitchen so this is pretty crucial... I have read suggestions saying you should start from a wall - I plan to do a 2 block tramline so guess this isn't appropriate
Thanks in advance!!! |
