Prima 80F - overheat stat trips occasionally
7 Aug 2007
West Midlands
I have a Potterton Prima 80F boiler on a fully-pumped system. Over the past few months, the overheat stat has tripped several times but I can't pin down exactly what's causing this. When it does trip, I've just had to reset it and it's then run ok for days or even weeks afterwards.
There are 3 stats on the boiler - the "normal" one for controlling the temperature; a pump overrun stat and the overheat stat itself. I guess any one of these could be playing up. The pump appears to be ok although i guess it's possible that it could be the problem.
Before I start the (expensive) process of replacing parts, does anyone have any suggestions either about common problems with this boiler or about how to pin down the cause of the problem.
Regards
Mike
sounds like your boiler stat is failing
CORGI IMHO I am afraid
should not be too dear
What number do you have it set on. I always set to 2 max!
You need to work out exactly when its tripping!
Might be a failing pump!
Does anyone know if these had a built in pump over run?
Tony
Tony
not too sure about the prima but the profile does tony
Yes, I know the Profile does but I dont think the Prima did.
If it does not have pump over run then scaling of the HE can cause the OK to trip when a demand for heat ceases.
I also wonder when the boiler was last serviced and the power input checked.
Tony
According to a manual I have they do have an overrun stat
well 30e-100e Prima f's do
Is there anywhere for the overunning pump to circulate water, ie a bypass or through a 3 port valve?
Sometimes a fixed (gate valve) bypass doesn't work and you have to fit an automatic one.
