I have been living in my present house for around 3 1/2 years and I have a real problem with efflorescence on every downstairs wall except the adjoining wall with next door (apart from a chimney breast on this wall). The house had a damp course done around 6-7 years ago, I called in the company that did the course as it was still under warranty and they advised me that they had already visited the house when the previous owner had called them in for the same problem and found that the damp proofing was OK and that the efflorescence would eventually go away over time if I just kept removing it from the surface.
All of the efflorescence occurs in the lower third of each wall and ranges from isolated patches on some walls to almost covering others. There is no obvious sign of damp in and around the affected areas.
i'm at the stage now where the walls look a total mess, the plaster in a lot of places needs to be replaced so I am planning on taking it all off back to the brickwork and having it replastered. What I want to know is what would be the best way to prevent the efflorescence from coming back?
