I have a 9901P Hotpoint washer/dryer, of late after it finishes the main wash cycle it pumps out all the water, it then fills with water again during the rinse cycle, it then drains out the water and for the final time fills cold water just before the spin cycle, at this point the water just keeps on filling and the drum does not fill up because the water drains out \\\"without\\\" the drain pump running.
I have checked there doesn\\\'t appear to be any valve around the drain sump pipe and the drain pump so wondering how this drainage is controlled as all the water that is coming in runs out of the drain pipe and therefore the machine just waits to fill up before it can move to the spin cycle.
Any ideas what to look for?
Thanks in advance.
Thanks in advance.
