Joined: 10 Aug 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Fri Aug 10, 2007 9:47 am Post Subject:
Hot and cold showers
I live in a flat in London in a converted three floor house. I recently had a combi boiler fitted but whenever I run the shower it goes hot and then cold. I have been told this is because combi boilers were not built to run showers and there is a backlog of water being heated causing the thermostat to cut out and therefore causing the cold periods. Other people in the other flats are probably using the water as well and this will be lowering the water pressure compounding the problem. Is this true and also is my only option an electric shower? Any help would be great. Thanks.
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Fri Aug 10, 2007 4:11 pm Post Subject:
Are you on the top floor by any cahance as water pressure will be worse up there.
Could be other problems like the combi going to overheat and shutting off, then coming back on when temp drops. You need to see what boiler is doing when shower is running. Do your hot taps work ok?
As Bahco says, you have been told a load of old c**p about combis and mixer showers.
Posted: Mon Aug 13, 2007 9:03 am Post Subject:
Yeah the hot taps do work and am on the first floor. Was told that because the hot taps use more water the through flow of the boiler is constant which means no backlog and therefore the themostat does not switch off. Whereas the shower uses a quarter of the water and causes this backlog which overheats and causes the thermostat to switch off. Is this to a load of c**p? If it is the boiler going to overheat and switching off is there any thing that can be done?
Posted: Mon Aug 13, 2007 8:26 pm Post Subject:
Just checked, the boiler is 'Glow-worm 24cxi' and the shower is a concealed 3/4" thermostatic shower value. Its apparently suitable for high pressure between 0.5-4.0 bar and is suitable for gravity fed, modulating combi boliers, pumped unvented and main pressure systems.
Is that enough info?
Posted: Mon Aug 13, 2007 8:37 pm Post Subject:
Have you checked that your shower head is not scaled up? I gather London is a hard water area.
Next get a bucket and measure a level of 10 ltres in it. Then see how long it takes to fill it. Try it will cold only, then hot only. Your combi should take about 1 min to fill this with hot water. If it takes longer then could be an inlet blockage or scaled up plate heat exchanger.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
