| Author |
Message |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41734 Location: London, United Kingdom Thanked: 1354 times
Posted: Fri Aug 10, 2007 7:00 pm |
My toilet seat won't stay up because it won't lean back past the vertical.
Either the cistern needs to be raised so that the front edge of the seat doesn't touch the lid of the cistern, and thus can go further back, or the pan needs to be moved forwards so that the seat will lean further back.
Which is likely to be easier?
I'm guessing the cistern, but I want to be sure before I put a new floor down.. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Terrywookfit
Joined: 19 Jul 2007 Posts: 1834 Location: Antarctica Thanked: 140 times
| Back to top |
timmy74
Joined: 30 Apr 2006 Posts: 340 Location: Durham, United Kingdom
Posted: Fri Aug 10, 2007 7:05 pm |
| Back to top |
Bahco
Joined: 08 Feb 2004 Posts: 7901 Location: Wolverhampton, United Kingdom Thanked: 79 times
| Back to top |
Agile
Joined: 26 Jun 2004 Posts: 46554 Location: London, United Kingdom Thanked: 2572 times
Posted: Fri Aug 10, 2007 9:46 pm |
Call back the idiot who fitted it.
He should have known better!
Tony |
| Back to top |
ChrisR
Joined: 24 Jul 2003 Posts: 23113 Location: London, United Kingdom Thanked: 945 times
Posted: Fri Aug 10, 2007 9:52 pm |
It's usually a case of changing or adjusting the seat hinges. How far off vertical is it?
Strong magnets?? |
| Back to top |
corgiman
Joined: 25 Aug 2003 Posts: 10598 Location: Surrey, United Kingdom Thanked: 45 times
Posted: Fri Aug 10, 2007 9:53 pm |
| ChrisR wrote: |
Strong magnets?? |
wow can you see them from there chris
impressive BAS
| Back to top |
ban-all-sheds
Posted: Sun Aug 12, 2007 11:11 pm |
| Terrywookfit wrote: | If its close coupled you are in s**t !!!  |
It's not.
| Bahco wrote: | Have you fitted the fittings that hold the seat ,the right way. Play with the pivot and fixing and you may get it to go back further.  |
Yes, it is fitted correctly, and at the end of its range of adjustment.
| Agile wrote: | Call back the idiot who fitted it.
Tony |
Indeed he should, but he's not contactable.
| ChrisR wrote: | | It's usually a case of changing or adjusting the seat hinges. How far off vertical is it? |
Have tried adjusting it - can't quite get the hinges far enough forward for it to go far enough past the vertical to stay up.
It's not a long way out, but it's far enough..... |
| Back to top |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 15983 Location: Hertfordshire, United Kingdom Thanked: 1933 times
Posted: Sun Aug 12, 2007 11:21 pm |
I want those shiny bars... I wana I wann....
I would say raising the cistern depending on floor and soil stack connection. A flush pipe and flexi would be less than a tenner +two screws and rawl plugs... Oh and the over flow... |
| Back to top |
clf-gas
Joined: 02 Mar 2007 Posts: 3453 Location: Lancashire, United Kingdom Thanked: 63 times
| Back to top |
ChrisR
Posted: Mon Aug 13, 2007 7:33 am |
You can get separate hinges, including stainless ones which adjust a fair way. Worth a lookout.
I once made the hinge very tight, so the seat would stay wherever you put it!
If it's one of those horrid wooden things, use a thinner one, or bury magnets into the wood and one inside the cistern! |
| Back to top |
Terrywookfit
Posted: Mon Aug 13, 2007 10:30 am |
You could always sit down and p**s lady style
Best bet would be to move pan forward unless its fastened down with gobbo!!
Flex pan connector and extended flush pipe only take you an hour!!! |
| Back to top |
masona
Joined: 05 Jan 2003 Posts: 12415 Location: Essex, United Kingdom Thanked: 103 times
Posted: Mon Aug 13, 2007 11:06 am |
Buy another difference toilet seat, I'm assuming they are not all the same standard sizes or are they? |
| Back to top |
sooey
Joined: 10 May 2006 Posts: 7818 Location: Merseyside, United Kingdom Thanked: 191 times
Posted: Mon Aug 13, 2007 11:17 am |
| Quote: | | You could always sit down and p**s lady style |
Great idea, if you read this characters posts on screwfix you'll see he is a complete f*nny. |
| Back to top |
ban-all-sheds
Posted: Mon Aug 20, 2007 12:40 pm |
sooey - thank you for your contribution. I'm sure the regulars on this forum value your mature and intelligent presence here.
Re the other ideas - have tried other seats - all have the same problem. The only one which was OK was the C&N one that came with the pan, and we've binned that....
There is no overflow pipe.
Raising the cistern would require a new flush pipe and a new section of inlet pipe.
Moving the pan would require a new flush pipe and a new stack connector.
6 of one, half-a-dozen of the other??
I'm not DIYing it, and I'm not going to get a plumber in just for that job as I've got bigger stuff on the horizon and I'll have it done at the same time, so I'm minded to decide that the answer will be to raise the cistern so that I can get on and lay the floor.... |
| Back to top |
