DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting a Dudley Niagara Dual Flush Valve
This topic originated from the How to page called Plumbing in a cistern
Click here to return to the page called Plumbing in a cistern.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
spartak96
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 11, 2007 8:42 am    Post Subject:
Reply with quote Thanks
We have a low level cistern (around 4 years old) I have had to buy a dual flush valve for it as the old "flushing" part of the cistern is continually letting water into the pan of the wc. The replacement I have brought does not have the old polystyrene float on it so how does the water stop flowing into the cistern when it's full? The float used to push up another part on the water inlet pipe and when full shut of the water but I don't see how the new one will do this
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
clf-gas
from United Kingdom
Thanked: 25 times
PostPosted: Sat Aug 11, 2007 9:41 am    Post Subject:
The float is internal
__________________
STUPID = Smart Talented Useful Person In Demand
Back to top
 Alert Moderators
spartak96
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 11, 2007 10:29 am    Post Subject:
Still dont understand. Sorry.
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Sat Aug 11, 2007 12:16 pm    Post Subject:
you seem to be confusing the flushing valve with the float operated valve. If you are replacing the flushing valve just fit it and see if it works.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
spartak96
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 12, 2007 9:08 am    Post Subject:
But the cistern does not have a float valve!! The centre part (being the section you flush) does not have a polysteyrene float on it. So as the water level raises how will the water know when to stop filling the cistern. Do I need to buy a new part for the water inlet pipe like an independeant float valve that will work on its own?
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Sun Aug 12, 2007 11:47 am    Post Subject:
All cisterns have float operated valves. Look at the point where the water supply enters the cistern. There will be some sort of valve on it. That is the float operated valve. Presumably it's working, filling the cistern and shutting off the flow when the water level is right?
__________________
Let's face FAQs.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Sun Aug 12, 2007 12:29 pm    Post Subject:
Seems to me you took the cictern apart and mixed up the float valve bits with the flush valve bits - they are two separate things. Have you still got the old bits ?
Back to top
 Alert Moderators
spartak96
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 13, 2007 11:25 pm    Post Subject:
What Chrishutt wrote is right, but the thing is it doesnt have a independant way of rising with the water that fills the cistern. That was down to the polystyrene float that is attached to the "flushing" section that I need to replace
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Tue Aug 14, 2007 5:33 am    Post Subject:
This is the Dudley Niagara dual flush valve. Where is there a polystyrene float on it and how is it attached to the float operated valve?
__________________
Let's face FAQs.
Back to top
 Alert Moderators
spartak96
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 14, 2007 5:51 pm    Post Subject:
Your right there isn't one on there. Thats what I'm saying. On the old one I removed (NOT A DUDLEY) it had one, which in turn assisted in shutting of the water when the cistern was full. So how will this work with the original valve??
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 14, 2007 6:09 pm    Post Subject:
I still think you are mixing up the two valves. Have you still got a water inlet valve of some sort - where the water pipe comes into. If you've thrown away the float, you'll need to get another one.
The flush valve does not turn the incoming water on/off. It just flushes !! icon_idea.gif icon_question.gif
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Tue Aug 14, 2007 6:40 pm    Post Subject:
Well none of us have come across such an oddity as you describe. Every cistern I've ever seen has had an independent flush valve and an independent float valve (ball cock in old speak). My guess is that you are mistaken in thinking that the two were linked. If you're sure you have an interlinked arrangement then please post a pic so we can all see.
I asked before if the float valve was working. You didn't reply. If it isn't working why don't you just fit a new float valve as well.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Thomas Dudley Vantage Dual Flow Concealed Cistern 8 2340 Sat Jul 26, 2008 1:49 pm
Grundfos Niagara 2.0 twin problem 4 200 Sat Aug 15, 2009 8:10 pm
Dudley Vantage Concealed Cistern 9 3620 Sun Aug 06, 2006 5:18 pm
15mm or 22mm - Grundfos Niagara 1.5 Bar pump 2 160 Wed Jan 21, 2009 8:37 pm
Fitting a dual flush system 2 140 Sun Aug 16, 2009 8:04 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
