DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Mixer Taps in Kitchen
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Lancashire Lass
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 14, 2007 10:59 am    Post Subject:
Reply with quote Thanks
Hi, New mixer taps fitted just over 12 months ago, however, recently the hot water stopped flowing, then restarted again. Now stopped again. Could need cleaning or washer replacing.
However, dont laugh, I cannot figure out how to get the tap off.
I have turned the flat top (coloured red!!) anti clockwise and it has come off, but underneath everything seems that it is connected together, thought I could unscrew the inside to clean it or whatever.
Will try to post a picture if you dont understand what I am trying to explain.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Aug 14, 2007 11:25 am    Post Subject:
You might have a tap with a cosmetic shroud has to be unscrewed before you can remove the valve body. A picture would help.
However, don't remove the valve body without isolating (shutting off the water to) the tap.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 1 time
PostPosted: Tue Aug 14, 2007 11:26 am    Post Subject:
Stuff gets trapped on the incoming side of the tap - we had this problem. I undid the connection under the sink and back flushed the tap by forcing water down the spout. (you can do this by holding some tough plastic material over the end of the spout and turn both hot & cold on, forcing the cold down the hot. Have a bucket under the sink where you've disconnected).
Back to top
 Alert Moderators
Lancashire Lass
from United Kingdom
Thanked: 0 times
PostPosted: Wed Aug 15, 2007 9:07 am    Post Subject:
Will make sure water is shut off before doing anything.
Having trouble with posting picture, so how do you unscrew a cosmetic shroud please.
Thanks again.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Aug 15, 2007 9:54 am    Post Subject:
If it's the type that unscrews, you just unscrew it.
There are many different types of tap, which is why a picture is invaluable. What trouble are you having posting one?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
mixer kitchen sink taps 2 820 Sat Sep 16, 2006 8:16 am
Older Kitchen Mixer Taps (circa 1985) 5 140 Mon May 25, 2009 6:40 pm
Advise needed with fitting kitchen mixer taps 2 500 Mon Jun 02, 2008 9:23 pm
Cannot undo Kitchen Mixer taps - Have bought crowfoot!! 5 1820 Tue May 29, 2007 9:34 pm
How do you replace the o rings in kitchen mixer taps. 6 720 Wed Feb 20, 2008 1:57 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
