Outlook 2007 Calendar Share Problem
15 Jun 2004
Norwich
I am trying to share my calendar & allow the other person full editing.
Every time I send it, it says review. If I send it then change the properties they still cant amend.
This used to work ok, but we had server problems & it was all reset. Is this problem to do with admin rights on the server.
I have been in contact with the company that give us IT support & they have said its all via my pc. I feel as though I have changed everything.
Thanks for looking.
If it's your calendar, then you do it from Outlook. Make the other person an Editor. They can then Open your calendar in their Outlook.
For info to others
I have sorted it.
You have to right click on the calendar this will bring up the options, select 'edit all', now you would think that in itself would do the trick, but no, you also need to select 'create item', but why.
Anyway sorted it
edit 8 Oct 07 to make clearer
