Security light connected to mains socket.
31 Jul 2007
Lancashire
I have a new security light to fit at the back of the house that I want to wire through to a plug socket in the garage.
The light has earth, neutral and two live connections. I assume one of the lives is a switch from the PIR.
Can I and if so how do I connect this to a three core cable from a normal mains plug socket?
Many thanks.
The switched live from the PIR will go into the terminal block and exit via another wire to the lamp holder. You only want to wire into the live, neutral and earth connections and these should be marked onto the terminal block. There is no need to touch the switched live.
Don't forget to fit a 3A fuse!
Thanks for that.
Problem is that the there are two wires (white) leaving L1 on the terminal block that have no feed to them. A white wire also feeds back into the negative on the unit side of the terminal block.
If the earth, neg and live are wired to the block as suggested and plugged in this trips the box.
I have no idea what will make this light work.
Please help.
[/img]
If this is a new light, surely it came with fitting instructions?
If not, you should be able to find them on the makers web-site
Failing that - you'll need to give us a photo
What box does it trip? :confused:
And if it has been wired incorrectly you may have knackered the PIR.
You NEED the manual.
