DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
single to double switch
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
monkeyballs
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 23, 2007 10:59 pm    Post Subject:
Reply with quote Thanks
Im trying to change a single light switch(RED,BLACK wires) to a double switch (one for the main light, and one for downlights) in the bedroom.
The single switch connected to light also had a pull cord switch which i no longer need, the wires for the pull cord switch are RED,BLUE,YELLOW,EARTH(neither end of this wire is connected). Do i still need this wire? On the new double switch the conectors are COM,1 WAY,2 WAY,(FIRST SWITCH) COM,1 WAY,2 WAY(SECOND SWITCH)...........can anyone help..........[/b] icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
comms
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 23, 2007 11:28 pm    Post Subject:
You need to find out which conductor is the phase (probably red), put that into terminal COM of first switch along with a link across to the COM of second switch.
Put the black conductor (should have red or brown sleeving on it) in to terminal 1 way.
Now you could utilise the existing 3 core & earth cable for the down light switching by inserting the red conductor into terminal 1 way of second switch if you have not already run new cable in (terminate the other unused conductors to the earth lug after sleeving in green/yellow sleeving.
Thats one way.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replace 1 x Double Switch with 1 x Single Switch for both.. 17 740 Tue Mar 13, 2007 2:40 pm
Single switch wiring to double switch wiring causing issues 31 1520 Tue Jun 10, 2008 10:48 am
Help replacing a double light switch with a single one 5 360 Tue Sep 09, 2008 5:42 pm
double switch and single dimmer wall switch 8 180 Tue Jan 06, 2009 8:38 pm
Change single to a double light switch 2 2140 Tue Apr 10, 2007 4:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
