Joined: 01 Jul 2007 Posts: 26 Location: United Kingdom Thanked: 0 times
Posted: Fri Aug 24, 2007 9:27 am Post Subject:
Leaking 1950\\\'s cistern
Hiya. I have a house that was built in the 50's and it has 2 cisterns situated in a cupboard in the spare bedroom. One is the normal black plastic one that you would find in the loft space. This is leaking from the ball cock valve and is full of water and the one i wish to repair. The other is an Asbestos compound tank that is huge. This tank is used for the supply of hot water throughout the house. This drains and refils normally and also has a working ball cock valve. The problem i have is that i dont know how to drain off the black normal tank that is overflowing, as i dont know where it supplies. Both tanks have pipes going to the cylinder that is situated underneath. Hot water, however, is heated via a boiler downstairs.
Does anyone know about this type of system and why i would need 2 tanks. Id like to repair the leaking ball valve.
Many thanks.
Meddy
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom Thanked: 20 times
Posted: Fri Aug 24, 2007 9:42 am Post Subject:
It sounds like the smaller cistern is the feed and expansion tank for the heating circuit. The heating circuit runs through a coil of pipe inside the hot water cylinder to heat it, but the water in the two systems doesn't (or shouldn't) ever mix.
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 192 times
Posted: Fri Aug 24, 2007 1:51 pm Post Subject:
Many warm air heaters had a small 3 kW "circulator" as BG called them which heat up the hot water either via a direct or indirect system. It was a small unit to the right ( usually ) of the warm air unit.
I am guessing that is what you have in which case there might be a drain off cock on it.
However, its not worth talking about as you can scoop up a little water out of the feed tank until the level is below the ball valve mounting hole.
You must bend the ball valve shaft so the valve closes when the level is just above the outlet. Thats a total level of about 100-150 mm in the tank.
Posted: Fri Aug 24, 2007 3:20 pm Post Subject:
Thanks for your help guys. The leak was coming from the nut that screws in the ball valve so will replace. Do you know what the black tank is used for? Someone said expansion, what does this mean? Can i keep the stop cock in the off position or is it needed, remembering that i no longer use the hot air system of my central heating.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
