DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
programmer
This topic originated from the Wiki page called Motorised valves
Click here to return to the page called Motorised valves.
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 9:48 pm    Post Subject:
programmer
Reply with quote Thanks
Last winter my siemans programmer stopped working, I bought a replacement RWB9.cw and wired up exactly as instructions and everything worked fine until summer (but as my heating was always on, no suprise as hot water came on with heating).
With the arrival of summer and no requirement for heating, I turned my heating off and used the hot water only mode, but to may amazement, the heating came on and the hot water also kicked in. I couldn't turn on the hot water without the central heating.
Upon investigation, and after consultation with a plumber friend of mine (who said it would more than likely be my motorised control valve). I bought and fitted a new sunvic 3 port motorised valve.
Now when switching on hot water, only the heating kicks in, the water doesn't get hot.
I would be grateful for anyone's advice on this.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
GeckoGas-com
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 9:59 pm    Post Subject:
Does the hot water come on if you switch on the heating?
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 10:13 pm    Post Subject:
I can't switch on the heating without the hot water also automatically coming on. I suspected that it may be the wrong way around, but I did fit the valve the same way as the previous valve, also the heating pump kicks in when the water is switched on.
Back to top
 Alert Moderators
GeckoGas-com
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 10:17 pm    Post Subject:
So, yes... The hot water comes on if you switch on the heating, correct?
To confirm the valve orientation:
There should be an "A" and "B" on the valve outlets....
The "A" should go to the pipe which goes to the radiators and the "B" should go to the pipe which connects into the cylinder.
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 10:30 pm    Post Subject:
it appears that the B goes to the cylinder - what do you think would happen if I turned the valve around?
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 12:29 am    Post Subject:
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Aug 27, 2007 9:54 am    Post Subject:
Does this new programmer have to be set for gravity or fully pumped with some dip switches on the back?
Take it off and have a look. Sounds like it is set for a gravity system.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 10:55 am    Post Subject:
it's got dip switches on the back and the last dip switch is for gravity/fully pumped.
I've double checked the position of these and they are all ok according to instruction leaflet.
As soon as I swithc hot water in on position pump kicks in and central heating is fired up.
I believe the system is a pumped central heating and gravity hot water.
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 10:58 am    Post Subject:
Not with a diverter valve it's not.
__________________
Regards
Dan Robinson
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 11:04 am    Post Subject:
Thanks Dan, I'll double check that then, I always thought when it was installed that it was gravity hot water.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Aug 27, 2007 11:09 am    Post Subject:
Needs setting to fully pumped then.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 11:25 am    Post Subject:
now set to fully pumped - but still with only hot water switched on, it's the central heating that comes on (without hot water).
Back to top
 Alert Moderators
GeckoGas-com
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 12:39 pm    Post Subject:
What Sunvic 3 Port did you use?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Aug 27, 2007 1:01 pm    Post Subject:
Wired up wrong or 3 port valve wrong way round or incorrectly wired.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
philsno1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 1:41 pm    Post Subject:
new valve sunvic SDMV2304
old valve was towerMP3 - 22C
I wired exactly as old valve and fitted valve with ports A & B in same position, also wired RWB9.cw as instructions.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
New CH Programmer - nothing works! 6 160 Wed Aug 20, 2008 10:56 am
Replacing Honeywell ST699 CH/HW Programmer with ST799 Model 4 480 Wed Sep 24, 2008 11:46 am
Honeywell (ST699B1002) programmer problem 3 240 Sun Aug 03, 2008 10:09 pm
programmer 6 260 Sun Aug 24, 2008 10:37 am
wiring up a programmable room stat to override programmer? 3 300 Mon Sep 08, 2008 1:39 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
