Switching on the Magic Eye
If you have plugged in a Magic Eye to the 2nd output on your sky box and the 12v supply is not switched on:\
On the sky remote control press the services button.
Select option number 4 (System Setup)
Now - using the numerical keypad press 0 1 Select (do not use the up and down arrows to select option 1)
You should now be at the Installer Setup
Change the RF Outlet Power Supply to ON
Select Save New Settings
Press the Sky button to exit
Note:
A magic eye or a compatible device must be connected before any TV, VCR, DVD recorder etc as the 12v supply from the sky box could cause damage.
If in doubt, consult the manufacturers instructions.
Page Options
Wiki
Search
Create or Find Page
