hot water working fine
turn on central heating switch and turn up roon stat and nothing happens.
looked at the honeywell motorised valve. It is T shaped. marked b, a and the one going down AB
If I move the lever manually to its futhest extent, then the heating and pump kick in. If I hook it on its latch, if just fails to kick in as if its coming back 2mm too much.
noticed 1 of the motor securing screws missing - might make a difference?
Have popped this head off to have a look at it.
what signals should I get on the wires - orange grey white etc when the heating is required and the stat closed etc
Have not seen the motor drive at all.
If i remove the power to the system, what reading should I get on the windings?
