Apologies as this is a re-post from last year, but I haven't sorted the problem yet ! Every time we flush the upstairs or downstairs toilets there are 2-3 seconds of gdunking and thunking at the end of the cycle. This started after I had turned the water off at the internal stop to fix a leaking downstairs kitchen tap. I am assuming it means that there are air pockets in the pipe.
So, are there any standard procedures for curing this? Along the lines of.... switch the water off, open the highest tap in the house, turn water on, turn tap off ? Except that didn't seem to work ! Or is it drain the system by opening all taps and then switch water back on with all taps open and then close them lowest -> highest. Or something else?
Any help appreciated
John
John
