Hi, I have a glow worm 24 ci combi boiler and recently opened the valve on a radiator that hasn`t been used for a good while ( spare bedroom) .A while later the boiler shut down with red fault light ( not sure if f2 or f4 ).
After switching off at the plug then on again all was ok ( green light ) but later on I noticed the pressure was at 1 bar and suspect some air was present in the mentioned radiator.
The problem is that I attempted to open the filler tube knob to increase pressure but although the knob turned fully no water was heard to enter the system. Since then the boiler will shut down every few days but will always work again when switched off then on.
Not being a plumber is this a big problem to get sorted, has anyone any quick fixes to free up the filler valve. Thanks, John
