I have an existing domestic size gas meter installed in my property, but will require a larger meter 16m3 capacity installed to cater for 2no.45kW boilers to serve a large extension. It looks like the supply pipe diameter from the road is 25mm yellow MDPE.
In your experience, have you seen these 1 inch dia. service pipes supplying U16 size gas meters before, and will it be adequate to serve a U16 capacoity meter (normal domestic size is U6 I believe).
