I don’t get to ask questions that often but here we go
. I’m fitting a cassette multi-fuel stove in a stripped out open fireplace. All the finish plaster was blown for 6-8 feet around the opening so most has been stripped off. Most of the original render is still OK & intact up to around a foot around the fire opening (been on there for 40 years!) & I went ahead & repaired the area up to the opening with a conventional sand/lime/cement render base which I though would be OK. I know that gypsum plasters are only good up to 50 degrees & so intended to use heat proof plaster on the area immediately around the opening but I’m now being told I should have used a heat proof render as well.
Now I could chisel it all off & start again but do any of you renderer’s know what the realistic maximum temperature a conventional sand/lime/cement render base is? Is it likely to cope with the wall temperatures around a cassette stove or is it likely to fall off?
Apart from the inconvenience of pulling it off & starting again, the heat proof stuff seems very expensive & I’ve no idea where I can get it locally at the mo. The dealer I spoke to also said it was a real pig to use so I asked if his guys could actually plaster but he didn’t answer that one; my diplomacy obviously failed me once again! ![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
