- Joined
- 27 Jan 2008
- Messages
- 23,861
- Reaction score
- 2,699
- Location
- Country
I have found I can get a 40% grant to change my old boilers for a new condensating type. But I have some questions I understand that I will need to change all the lock shield valves if I move from open vented to closed vented other than damage limitation in case of a leak what are the advantages of a closed vented system? I can’t run any hotter as I have some radiators which can be touched by hand so are limited to 70ºC.
Second is I have a Myson radiator in the main room as with the open plan stairs it needs a lot of heat it at 4Kw was not big enough and I added a 2Kw double radiator with fins in only available space. It would be a backward step to get rid of the Myson however from what I have read the condensating boiler measures not only out going water temperature, but also the return!
Now the Myson as is has no restriction on water passage and is feed with 10mm copper and is thermostatically controlled by switching the fan on and off. This would mean as soon as the thermostat turned off then hot water will be returned to the boiler. This would switch the boiler down which if within limits it not too bad but I worry it would reduce to output so much that other rooms could not heat up.
I have not seen a modern Myson this one is 30 years old and I wonder if the new type has any valve to stop or reduce water flow? Since it has a sensor to stop fan starting until the water is hot I would consider a reduced flow would be best option. I would have expected something like the valve used to fill a washing machine rather then one of the motorised valve type.
My parents have just has a complete new system under the grant and the people doing the work did not even realise that they could not use a power shower on a instant mains pressure system so I don’t trust them to advise.
Has anyone any information as to how a Myson will work with a condensating boiler please and if there are any alterations to the modern Myson to old type?
