I just drill 20mm hole through cavity, pass through 20mm round conduit and pass cable through that. What a joke.
We should protect the cable through cavity anyway.
Life is rarely that easy - if the masonry bit head is no bigger than the conduit, then the hole/have has/have to be exactly straight for the conduit to pass through easily.Choose a drill bit with the head equalling the size of conduit.
Hitting a wall tie is an indication of bad luck, not incompetence.If you drilled a hole where the inner and outer did not match up more than once , why did you dot learn your lesson or learn to drill straighter/more accurately.
He said "I'll get my tool from the van", and it was a coathanger, which naturally I thought "God you don't even know whats in the inside of that cavity" my health and safety background came into force
mattt1e non of Sharon's 50k was budgeted for vodka what's that all about
