Hi peeps,
My dimmer switch isn't working and I'm looking for some advice before replacing as I'm not sure if this will fix the problem. I'm a DIY amateur but can change a light and dimmer switch but as say, don't want to do that as unsure if that will fix the prob.
I have a dimmer switch in my sitting room. It's been there since the property was built and was installed by builders. I fitted a 5 light to the ceiling which used 5 x G4 12 volt bulbs. Pushing the dimmer switch brought the light on/off but the dim function (turning the button) wouldn't work and the switch buzzed louder than usual for a dimmer switch when I tried to dim.
A search on google made me think that the switch might not be suitable for halogen? Don't know if this is accurate or not.
Anyway, I recently changed light again to a 3 x E14 candle bulb light type. I thought that would solve the problem but it hasn't, it still won't dim.
When I try to dim it seems to be just bright or very faint glow which flickers and after few seconds just goes out. I then need to switch the dimmer off/on again and it still only goes to totally bright or very faint glow and then switches off.
As it was fitted when property was built I don't know anything about the switch, just seems to be a standard dimmer. I've fitted dimmer switches in previous home which worked no problem, they were just bog standard dimmer switches from B&Q. Light in previous property was similar to current (3 x E14 candle bulb fitting).
I am unsure if replacing dimmer would work and before did would be really grateful for an idea of what I should get.
Thanks in advance for any help,
Julie.
Julie.
