hi i recently installed a new radiator and now after 30 minutes my boiler loses pressure and ideas?
yes 1.5barI assume you've re-pressurised the system via the filling loop?
would a leak not be noticeable??????Adding a TRV wont cause the pressure loss, if you are certain there are no leaks from any of the glands etc... maybe some of the pipes wewre disturbed at a place where its not obviously visible?
are you a rgi?Bleeding the system wont do any harm to your Expansion vessel. If you are concerned it may be let some air out the valve, if it squirts some water out its toast.
