Hello all
Hoping this is a simple one.
I need to plaster a wall which has a PIR in the top corner. I need to temporarily disconnect the PIR and probably take the sensor off the wall for a while.
I figure there may be 3 options:
1) shut the power off for the house before then disconnect PIR. I suspect this will this make no odds - alarm does have battery backup.
Was reading some posts on PIR replacement.
2) I have got the engineer code for the alarm, so do I put this in and then try to disconnect power and return at the PIR?
3) Need to disconnect at the alarm panel first?
4) something else (sorry, new to this
