Where in the bathroom under the current BS7678-2008 can a pull cord isolator be installed for the isolation of a shower.
Many Thanks
Erm... on the ceiling
Afaict the switch itself must be outside the zones (note: zone 3 doesn't exist anymore) and the insulated pullcord can drop into any zone.
Usually the ceiling is high enough to be outside the zones but there are some properties where it isn't which can pose a problem.
What I meant was are they designed to be operated several thousand times?
You're assuming it is a household. It may be a place of work, in which case it will cost a darned sight more to replace it on an annual basis.What I meant was are they designed to be operated several thousand times?
It may be one of the households where it's never switched off.
Besides at a tenner a time who cares if it only lasts a year.
