- Joined
- 27 Jan 2008
- Messages
- 23,765
- Reaction score
- 2,680
- Location
- Country
It is not a normal inverter but a grid tie inverter and these auto synchronise with supply and from what I have read in last few days auto close down if incoming supply fails.Gosh, anyway, thanks for the diagram pasty. Whilst I too have reservations and hopes for the future, your question was simply about using an existing CU with a spare way. Given your description and the diagram, then I still don't see how you can put power into an existing CU without having problems with matching cycles if nothing else. I would have expected that the two power supplies need a joint terminus which would syncronise the inverter with the mains before supplying the CU or exporting. Or have I missed something?
I would like to know more about inverters also. One big question is are they MPPT? (Maximum Power Point Tracking). It seems both solar panels and wind chargers give out the maximum wattage at different voltages according to the amount of sun or wind. By allowing the voltage to vary one can get quite a bit extra power and they will still produce with very little wind or sun rather than old style where they had a cut off point.
However for battery regulators loads of info but for grid tie inverters there seems to be very little. One would assume if they had MPPT they would tell us all about it so I assume they don't!
