If you have 2 completly seperate supplys, both TT and they are right next to each other, is it exceptable for them to be both of the same earth rod???
Drained 3 batteries on my 24V makita just doing one 12mm hole through a ~60mm thick wall.
Are you aware that the code of practice says you should discount the first metre of buried rod? That is, a one-metre rod is not considered to give reliably low and maintainably stable readings. Also, separate rods need to be spaced sufficiently far apart that they do not influence each other - and that will depend on their depths, soil resistivity, type and cross-sectional shape and area of the rod/s, etc.Thanks all. Think i will just put 2 rods in. What i was thinking of doing was fitting 2 rod clamps on the 1 rod but because the rod is inside and most probably will not give a good reading, i will fit 2 new rods outside.
dingbat";p="1787089 said:Relative to everything else an electrician encounters, the business of earthing is complex. It is not as simple as whacking in a rod, peeing on it and taking a Ze measurement, as many seem to think.
Some people just have to ruin the nice bit of the job
