Hi all,
Sorry if this question has come up before but i cant seem to find any info on it.
I have just moved into a new flat, it has a combination boiler with 5 radiators, i wanted to adjust the temperature in each individual room by using the wheel head valve, the problem is the radiators seem to have matching wheel head valves at each end.
Im not familiar with this setup, as usually i would have 1 wheel head valve which i can adjust and 1 lockshield valve on the radiator. In the meantime i have turned both sides up, but does anyone know why i would have 2 wheel head valves on the radiator? and also would i have changed the balancing by turning both valves up?
Thanks in advance
Thanks in advance
