We have a Remeha system boiler in the kitchen extension, with a Honeywell CM927 managing the temp with the the sensor in the extension as that's the coldest room. That works well, no problems.
However, some of the rads were changed and also had TRV's fitted (Pegler Bulldogs). It seems that these TRV's do not manage to provide a stable temp; they seem to function more like a standard valve which is adjusted to give more or less flow. They will, if turned to extremes, shut off or stay on, but when a setting equilises, there is allways a flow when the boiler is on.
The result is that, as the outside temp rises, the room is getting too warm.
I thought that a TRV should, given enough hot water, maintain a stable temp and not go too warm.
I would like to ask some advice as to whether I should look at replacing these TRV's as I have a Honeywell and a Regis (TRV) in other rooms that seem to be more consistent at maintaining a stable temp.........or am I doing something wrong?
