Hi all, i have just moved into a new house which has a Bosch boiler (Not sure which model), a lifestyle LP111 timerswitch and a Seimens Landis And Staefa RAA02 thermostat.
All works great, however the timerswitch only has two settings which is no good for my shift work. I have seen that you can simply replace the front unit and use existing backplate which would be a godsend - question is - what model and make can i use as a direct replacement? I need mon-fri and sep sat/sun settings and also 3 per day is a must.
Is the LP711si ok? - I am savvy with electrics so swapping wires is ok - just would rather not?. All help most greatly appreciated.. Cheers!
