I have just seen that the pressure gauge is down at 0 and have attempted to fill it up in the correct recommended manner, three times. When the grey knob is turned you hear the water flow for about 3 seconds then silence with no movement in the pressure gauge.
The boiler has been running on constant 24 hrs a day at 16 degrees c since October. It still is firing and heat is still coming from the rads, but no movement on the pressure gauge even if I increase the temp for five minutes.
Is there a filling fault?
&/or
Does the pressure gauge need replacing?
Any other suggestions?
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
&/or
