I am having a problem with air in my open-vented central heating system. I checked out the Honeywell mid-pos valve and it appeared to have been weeping so I guess it is this that is introducing air. Having tightened the nuts a bit it doesn't appear to be weeping now but it seems like air is still getting in.
The symptons are:
Slight bubble occasionally in radiators, usually when boiler turns off and pump stays on, also on cold startup.
When valve moves to HW mode there is an audible and random clicking noise which sounds like air bubbles through valve (valve is quiet on CH mode).
1. The valve is after the pump, could this still introduce air (seen references to it when on the low-pressure side)?
2. If it doesn't appear to be leaking water, could it still be introducing air?
Many thanks to anyone who can help.
Neil
The symptons are:
Neil
