I've got a radial socket circut upstairs.
Best I can tell, this goes from the CU to a junction box somewhere under the stairs, and then in a star shape to the 4 sockets connected to this circuit. I've only got one cable from the CU & each socket has a single cable, hence the radial & shape assumption?
(These are on the near and far walls of each upstairs bedroom)
I can't get much more than this without pulling the floors up.
Rooms are both 3.38m x 3.38m, so I believe I'm well under the size requirements. The star shape concerns me a little, but not overly?
Circuit is run in 2.5mm² cabling througout on a 20a MCB, with a single RCD in the board (Volex, will get full details if necessary)
I'd like to add a fused 'spur' to connect some model railway bits to in the front bedroom. I've got plenty of 2.5mm² cable, which I intend on using.
Thoughts please peeps, particularly anything I've forgotten?
