Hi, have an LG50PS3000, 16 months old. 3 weeks ago picture occasionally would go slightly fuzzy & pink tint. Then tv would switch itself off & have to be switched back on.
Last week it switched itself off & would not come back on at all. Well, it would light up the screen for a split second then go off.
Called a local tv repair guy who took it away for asessment. He reported that the power supply unit had overheated 'like they do on these tv's' due to the power supply being 'not up to the job of coping with the heat'. Also may have affected a pcb next to the psu.
£200 later! the tv was returned with new psu fitted. When repair guy connected tv, the picture was again a bit pink & fuzzy, but some mumbling about 'switch power off & on again' and all seemed ok This has since happened 3-4 times since, although hasnt switched itself off. He has advised to try to narrow the fault down by running the sky hd through a scart instead of hdmi. Doesnt ring true to me?
He has obviously fixed something, but not fully. What you reckon?
