Unoccupied small flat has a 6 way 3036 CU
It also has a 4 way 3036 CU for off peak heating.
Only the CU's are visible service head and meter in some other part of the building, as yet to be found.
Would appreciate some insight how this may be wired.
The heaters are storage heaters. which will charge up over night, but with this set up I presume can't be turned on during the day (If all heat has gone)
Was that common for this form of heating.
Would like to change the 6 way CU and leave 4 way as is..
I don't think it applies in this situation but it got me thinking, if the power to the storage heaters was switched between two CU's for peak off peak, would upgrading one CU and not the other cause issue. Don't think so , but thought I would ask.
