Are you sure space blanket insulation complies with regs?
Why are you so desperate to keep the bloody purlinInsulation is not a problem as I have the space blanket insulation and not kingspan due to keeping as much head height as poss. I believe that middle purlin is carrying the majority of the middle section of weight and just believe I need to support that purlin at differnet points as much as poss we have a stud wall coming off a brick internal wall from the first floor upto the purlin in the middle of the loft thus seperating the loft into 2 large sections. We are alos doing hte same off internal birck walls at one end as we are having fitted wardrobes the problem is the other end as their are no walls underneath to pack off to go upto the purlin.
I understand your concern, and if it was simplest solution to resupport the purlin, I'd be right there with you. But it seems that resupporting the purlins is pretty difficult to do, whereas strengthening the rafters is relatively simple.Thanks for the replies you have given on my thread, I will get you those measurements tomorrow I am just worried of taking out the purlins and the roof sagging in as the bloody SE did not calculate the weight going to the steels. So by sistering the rafters from the lower purlin to the ridge that shoudl support the roof structure? I am not worried about the lower section as I have noggins going upfrom the steels to the lower purlin it was the weight of the middle section pushing inwards which is why I was planning the small stud walls from internal walls upto the middle purlin.
Respectfully ibby, I would suggest you try not to embarrass yourself too much.I see a small problem,
you have not painted the steel in red oxcide paint.
I would have also doubled the rafters and left them single.
I know and jeds done a pretty good job of it, no need for my input there. Though I don't really understand your last post in that thread.
Really though if you employed a decent professional instead of the buffoon you seem to have employed this would all be taken care of.
Sack this one then he will cause you no end of grief and you will be on DIYnot double checking his work and having to rap his knuckles on everything he does.I know and jeds done a pretty good job of it, no need for my input there. Though I don't really understand your last post in that thread.
I am not knocking his work!
I always get with the bauffons!
edit - this is my 2nd guy, I have already sacked one!
