- Joined
- 27 Jan 2008
- Messages
- 23,765
- Reaction score
- 2,680
- Location
- Country
Both batteries are NiMh's you can't buy NiCad's any longer except for military or medical use. And although there are some odd re-chargeable alkaline batteries at 1.5 volt these are rare and in the main you can't use a Delta V charger to charge them.My wife proudly said how she had got a pair of 800mah for a pound compared with the 4 x 2500mah batteries I got for £2.98. But did I really get the better buy? Hers were ready charged and are claimed to hold charge for 1 year and mine had to go straight into the delta V charger.
There's many types of rechargeable batteries, the main ones are NiMH (Nickel-metal hydride battery), Nicad and LiPo (the latter, Lithium Polymer) are rare in AA form at this time), they all hold charge at different rates.
Nicads discharge the quickest, NiMh the second whereas LiPo can hold their charge very effectively for up to a year. They all perform differently too.
Do you know whether the two batteries you're comparing are of same type? Nicad's will generally be cheaper than NiMh's. Also, are they both 1.5v, generally the cheaper rechargeable's tend to be 1.3v.
Most rechargeable AA cells are 1.2/1.3 volts the 1.5 volt is rather rare. The problem is the amp-hour ratting this varies from 600mhA to 2500mhA reading Wikipedia it seems there are 2700mAh versions.
There are a number of factors Ah rating ability to hold charge, voltage and internal resistance but in the main the normal punter only looks at the rechargeable tag. Add on to this the charger paramours and it goes well beyond the ken of the normal punter.
This is my point to my mind it seems there is a big con with some retailers marketing batteries well below the norm but at a good price and conning punters to buy cheap rubbish.
